Home > General > Hope he's wrong |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
Sorry it's a 2.7 sport |
Tue Aug 15 2017 8:58pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
When were cambelts done, was oil pump replaced?
Tue Aug 15 2017 8:59pm |
Cambelts done last year less than 4000 miles done
Tue Aug 15 2017 9:05pm |
No didn't replace oil pump when I enquiried
Tue Aug 15 2017 9:07pm |
The oil pump often goes following the cambelt change mine did 15k following cambelt change before oil pump tensioner sheared off, it's not looking good ....... Fingers crossed for you Nanocom Evo |
Tue Aug 15 2017 9:13pm |
Ok mate find out Thursday I hope
Tue Aug 15 2017 9:18pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4333 |
Sounds like oil pump. Generally a few K'S after having the belt replaced... |
Wed Aug 16 2017 6:53am |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Should you always change the oil pump then, even on later models (MY2012) when cam belts due for change?
Wed Aug 16 2017 2:11pm |
That's a good question my friend
Wed Aug 16 2017 7:25pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8838 |
There was a batch of cars where LR decided to fit a different oil pump casting. This casting is, it seems, weaker than the original but was presumably done to save a couple of quid on the build cost. Following a number of failures, they changed back to the stronger casting. The affected cars are around 2007 I think. The weaker casting seems to be fine until the belts are changed. A few k miles thereafter it has a tendency to fail.
Wed Aug 16 2017 8:25pm |
It affected 05-08.5MY, and a very small number of 09's All 3.0 were fitted with the uprated pump |
Wed Aug 16 2017 8:46pm |
Many thanks for that info Disco_Mikey.
Wed Aug 16 2017 8:55pm |
