Home > General (L494) > Hello |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Welcome to the SDV8 club! I think it's a phenomenal car, but not everyone on here agrees! ....but how come it's a 2016 if you're the first owner, or is that a typo?
Mon Aug 14 2017 10:38pm |
espaceboy Member Since: 13 Aug 2017 Location: Fife Posts: 28 |
Thanks for the hello. yes 16 plater, Previous owner was landrover, car was used by the sales team for its first 7000miles.
Mon Aug 14 2017 10:48pm |
That's a bugbear of mine, there's a nice sized box perfect for storing glasses that they went and wrecked by shaping for drinks - why not leave it square as there's plenty room underneath, and then sell inserts the shape of drinks...let us choose! My XF was the same, really annoys me having that wasted space. I've the L320 so there is the tray on top of the fridge but no room to keep in a case to protect from scratches. I'm interested in your idea for a holder. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Mon Aug 14 2017 11:03pm |
Yup, you need shades to hand in a dedicates slot, not in a general cubby being scratched
Mon Aug 14 2017 11:13pm |
The Land Rover CTEK, as you're probably already aware, is poor value, but also under-rated for the car, especially with the V8 diesel battery. If you search the forum, you'll find threads on this issue including lots of recommendations as to which CTEK to go for. I bought an MXS-5 (£57 on eBay), others went even bigger. Unlike the LR one, this also has a much more sophisticated charging cycle, and the top models allow you to use 12v in your car while it's plugged in and the engine is off, which some find useful (listening to the radio while cleaning the car?). As it happens, despite low miles (2,500 in almost six months) and lots of short journeys, the battery has been fine, and even stop-start works all the time (if it doesn't, it's usually a symptom of low charge in that battery) - maybe I'll need the charger more in winter(?). The 'comfort connector' (stupid name!) I bought is the CTE-56380 (https://www.amazon.co.uk/dp/B002OHXX60/ref=pe_385721_37986871_TE_item) which I got for £19.95. If you look for the installation instructions for the LR version, (which is identical except the LR one has no traffic lights), it shows you how to install it. The connector has eyelet terminations which fit on the battery positive and fixed earth. For a neater finish, and to shorten the cable run, I accessed an earth on the right hand side rear of the spare tyre-well, rather than the route the LR instructions follow. You could, of course, fit eyelets to your existing comfort connector, but I guess that one isn't panel mounting, which makes a much neater job, and maybe the cables would also need extending. I'm away for three days at the moement, but I can send you pictures of mine installed later in the week if you'd like. |
Tue Aug 15 2017 8:42am |
My glasses fit (in their case) in the small space at the forward end of the sliding centre-console cover. These are 'aviator' style specs. so not all that slim. For those yet to purchase an RRS, the extended trim versions come with 'cubby boxes' in the doors utilising unused space under the door pulls. |
Tue Aug 15 2017 8:46am |
Thanks for the Ctek cable info, very interesting. I couldn't find the LR install guide though so any info appreciated.
Tue Aug 15 2017 12:56pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
As a SDV8 owner I must agree, a great car with heaps of get and go with excellent fuel economy. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Aug 15 2017 1:21pm |
milesg Member Since: 24 Aug 2012 Location: UK Posts: 64 |
Same as mine, loving it!!! 2016 RRS Autobiography - 4.4 TDV8 - Santorini Black with Ivory Leather - Grey Alloys - A few toys |
Tue Aug 15 2017 1:27pm |
Thanks all, what a real friendly bunch.
Tue Aug 15 2017 1:38pm |
Hi, I'm back, so here is the link to the fitting instructions: http://accessories-instructions.landrover....1781829920 The LR connector is less sophisticated than the one I recommended, and the charger less adequate, but otherwise the fitting is identical. As I said above, I'd run the negative cable to the right hand side of the spare wheel as there is a readily-accessible earth point there and I can vouch for the CTEK cable being long enough. The eyelet terminations supplied are large enough for both the battery +ve and the earth point. It's a lot easier to do than their instructions make it look, by the way! I wouldn't personally use a permanently live 12v socket, this is a much superior solution. If you do go the permanent live route, be careful what you connect when the engine is not running as people seem to find the electronics susceptible to even modest discharge (although I haven't had any problems myself). There are loads of threads on here on this very subject! |
Fri Aug 18 2017 9:40am |
thanks for the reply and the instructions, this does look neater and your point is noted on discharge risks on Aux sockets.
Fri Aug 18 2017 10:08am |
Sorted! |
Fri Aug 18 2017 10:10am |
Triple7 Member Since: 27 Oct 2011 Location: Wiltshire Posts: 154 |
Whats CTEC? Gone:
Fri Aug 18 2017 9:27pm |
