Home > Maintenance & Modifications > Upgrade door cards
Cbr60rracer
United Kingdom 2005 Range Rover Sport TDV6 HSE Lux Bonatti Grey
Upgrade door cards
Hi has any one upgraded their door cards to 2012 autobiography? Any assistance particularly in wiring would be helpful please
Regards Very Happy
Post #532672 Sat Aug 12 2017 5:40pm
jimmybeituni
United Kingdom 2006 Range Rover Sport TDV6 HSE Alaska White
do you know if the seats from a 2010 autobiography fit a 2005 rrs
Post #535396 Thu Sep 14 2017 8:27pm
Johnski
Re: Upgrade door cards
Regards Very Happy
I think the price may put you off, to replace a door card on MY12 SDV6 is £830.00 inc VAT discounted price at Duckworth LR Parts. Big Cry You have to supply the VIN number and they are made to order. Whistle
All this just for a damaged speaker grille (small hole) which can't be purchased separately only the whole door card! Embarassed John
Post #535399 Thu Sep 14 2017 8:38pm
Cbr60rracer
Hi
I recently done just this you just have to swap the original wiring onto seat frame. Takes a little while and only connection you need to make is the heated seats. Just cut original wire and connect with a double end connector and it's done .
I just put some 2013 new leather on mine also, that's a pain but worth it.
Regards Thumbs Up
Post #535400 Thu Sep 14 2017 8:43pm
Cbr60rracer
Johnski wrote:
Regards Very Happy
Hi
I managed to get a full second hand set of eBay £200 and looks so much better now. Slight variance on window switches which leaves a little gap but got some Matt chrome surrounds from china which stuck on and look pretty much original fitment. Your right about new prices so expensive like most things seem to be Big Cry
Post #535401 Thu Sep 14 2017 8:46pm
jimmybeituni
thanks for that i have just bought front and back seats and now panicking they won't fit the bolt holes are all spaced different but i don't think that will be a problem, did you have the same issues
Post #535402 Thu Sep 14 2017 8:48pm
Johnski
Well done managing to get a whole set, and not a bad price, did your speakers match and fit, as some have upgraded sound system fitted with a different grille layout? John
Post #535403 Thu Sep 14 2017 8:52pm
Cbr60rracer
Hi
They will fit alright.
Take care and disconnect the battery at least half hour before you start.
Rear section in two parts feed through from the rear to save door cards getting scratched.
Also recommend getting someone to help you get fronts out, they are a pig as heavy. Easiest way is lift as far forward then straight out sideways.If you have an amp under driver seat you'll be glad of help as likely to get stuck.
You'll also need to take off original seat belt tensioners and transfer over.
Regards
David
Post #535404 Thu Sep 14 2017 8:54pm
Cbr60rracer
Hi
Yes speakers were ok, only difficulty is wiring looms different on newer ones so the locking buttons on driver door become only decorative , still ok though as retain original on dash.
Post #535405 Thu Sep 14 2017 8:57pm
