Home > In Car Electronics > denso touch screen |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
They are called Fakra Connectors and they are colour matched i.e Brown will only fit Brown, however there is one colour which is universal and will fit all colours, it is a sort of blue/green probably called Aqua but that is a guess.
Tue Aug 01 2017 2:02am |
rostan242@gmail.com Member Since: 15 Sep 2016 Location: Alfreton Posts: 28 |
Thanks for the reply
Tue Aug 01 2017 7:28am |
It won't work as a reverse camera unless you cut the middle touchscreen cable to make it think it's a Range Rover. And you need to have reverse camera enabled in car CCf.
Tue Aug 01 2017 8:04am |
When I did mine I did use a GVIF unit as I also fitted a TV Tuner and the Rear Entertainment/DVD etc. on to the front screen as well, which I guess would explain why I never had to modify the screen at all.
Tue Aug 01 2017 8:58am |
It was just my idea of what to pay for "gvif" since it can be checked at low cost. 9-pound adapter
Tue Aug 01 2017 9:25am |
You'll soon get off with having to spend 20 seconds getting to the secret menu every time you want to reverse. Bodsys Brake Bible
Tue Aug 01 2017 12:22pm |
