Home > General (L494) > warranty on less than 2 year old car ? |
Triple7 Member Since: 27 Oct 2011 Location: Wiltshire Posts: 154 |
The car comes with 3 year factory warranty, so on a 2015 you will get that plus the dealer will top up to 2 years with the 'Approved used' warranty. The latter is almost the same. If you get an 'extended warranty' then they will charge you for diagnosis, if the issue is covered by the warranties t's n c's then the dealer passes the dignosis bill to LR. If it is outside of warranty items, then you get to pay all of it. Gone:
Tue Jul 25 2017 1:58pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1133 |
Hi,
Tue Jul 25 2017 10:42pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
The Approved Warranty covers almost everything bar suspension bushes, glass and broken wires. Short of the original factory warranty, it's about as good as it gets. You also get LR Assist which is excellent. 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 26 2017 7:27am |
