Home > Technical > IN CAR DVD |
I have been having problems with the loading of DVD's on the rear DVD player. Took the car into my dealer who have come back to me telling me that this is a known LR problem and will not replace/repair the DVD unit until a fix has been found! I asked how long this could be and the service manager told me anything from a week to a year! What are LR playing at here? Has anyone had a similar problem or am I being fed bull? 2005 Zambezi TDV6 - Gone but not forgotten
Thu Jan 04 2007 2:19pm |
If it's a mechanical issue can they not just replace the DVD drive? Or is there more to it than that?
Thu Jan 04 2007 2:52pm |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
It doesn't work !!!!!!!!!
Thu Jan 04 2007 4:34pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Yeah to right if they don't ring trading standers and see what your rights will be to this! RRS TDV6 Gone but still around
Thu Jan 04 2007 4:59pm |
What is the 1979 sales of goods act? RRS TDV6 Gone but still around
Thu Jan 04 2007 5:26pm |
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 |
Land Rover really don't need to do anything.....nothing new there then. Under the act its up to dealer and you really don't need to put up with any of their rubbish. My factory fitted system works fine....therefore they can get it to work:- Here is some legal stuff you can quote to them, but do take note of the last para:-
Thu Jan 04 2007 5:34pm |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
VA, can you describe the problem in more detail? There are a handful of TSBs recently issued regarding RSE malfunctions, I will be happy to look them up for you and see if any of those may apply. I, for one, sometimes find that disc # 1 (out of the 6 in the changer) is "locked out" and I can no longer select it unless I remove and reload the magazine in the changer. There is now a TSB for that. |
Thu Jan 04 2007 5:37pm |
Basically my system can only find disc 2 & 4 and will skip the other 4. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Jan 04 2007 6:09pm |
VA, it does that even after you reload the magazine in the changer? Besides the obvious (DVD loaded the wrong way, incorrect region code), it sounds like a faulty changer to me. My problem and fix for it are detailed in the TSB below (LS415-005, rev. 3). I wonder if the same revision may fix your problem as well, although yours sounds more hardware-related to me.
Thu Jan 04 2007 6:32pm |
umbertob - yes it happens even when I reload the cartridge. My dealer says it's LR HQ that wont replace the system, he has requested the replacement and LR wont give him one until the bug has been fixed! 2005 Zambezi TDV6 - Gone but not forgotten
Thu Jan 04 2007 7:01pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Sounds like a fob off doesn't it, it didn't used to do it and others don't do it but it's a bug!?!?
Fri Jan 05 2007 9:55am |
Good idea. I can't understand why they think it's a bug when it sound pretty much like your DVD drive has gone faulty. Where's the problem in simply replacing it?
Fri Jan 05 2007 10:02am |
I thought that all the thing inside and out was under warranty??
Fri Jan 05 2007 10:24am |
The dealer admitts it is under warranty but say LR refuse to replace it. I've ask for confirmation of what they've told me then I will speak to LR themselves! 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jan 05 2007 10:35am |
