Home > Faults & Fixes > Starter solenoid clicking |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 32 |
Poor connection, check the earth cable including engine to body is secure. |
Tue Jul 04 2017 6:35pm |
Rainboy Member Since: 26 Feb 2015 Location: glasgow Posts: 25 |
Will do,thanks for ur help,cheers👍🏻 |
Tue Jul 04 2017 7:17pm |
Had the same issue on and off for weeks. At the same time the front parking sensors were intermittent and 'phone sometimes failed to pair on starting up. After a while all returned to normal even though I had not found the fault. Then the alternator failed. I can't help thinking the faults were in some way related to the alternator going bad. It was a diode that had blown up.
Wed Jul 05 2017 1:39pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Mine did that when the starter was on its way out. New starter cured it, obviously. 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 05 2017 3:34pm |
Hi,thanks for all of ur answers to my problem,my front parking sensors have also been playing up so I will get the earth strap checked and maybe just replace the starter😫,thanks again👍🏻 |
Wed Jul 05 2017 5:57pm |
