Home > In Car Electronics > Replacement headunit options |
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 |
Just a thought but
Fri Jun 30 2017 8:09am |
HS66 Member Since: 12 Apr 2016 Location: Surrey Posts: 38 |
The amp looks ok, on the headunit it's not displaying the volume when you turn the knob up and down so thought if the amp was at fault it would display the volume but there would be no sound?. |
Fri Jun 30 2017 9:39am |
It's usually the Amp, but sometimes the head unit.
Fri Jun 30 2017 11:23am |
Ah, mine is only an SE so doesn't have the nav screen. |
Fri Jun 30 2017 11:54am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Think it does that if there is no optical fibre network connection at the HU |
Fri Jun 30 2017 12:06pm |
Mine also didn't show any input when I turned the dial up or down
Fri Jun 30 2017 2:15pm |
Thanks guys, so something could have come loose at the back?, or sounds like it could be the amp?, I'm fine with buying either a new amp or headunit I'd just rather buy the one I actually need!.
Fri Jun 30 2017 3:15pm |
star panels?
Fri Jun 30 2017 5:10pm |
Sorry, was typing on phone, I undid the headunit from the facisia that was held in by star type Allen keys but it still didn't want to come out. |
Fri Jun 30 2017 7:39pm |
you probably need to lift (read pry) away from the climate control panel |
Fri Jun 30 2017 8:19pm |
