Home > In Car Electronics > Aux input
Alanfolling
United Kingdom 2008 Range Rover Sport TDV6 S Bonatti Grey
Aux input
I just purchased the aux input for the rear console and plugged the cable in but I don't hear any music when putting stereo into aux mode
My car did not come with the aux fitting as standard. Hence I purchased
Any ideas ?
Post #529279 Thu Jun 29 2017 7:14pm
Alanfolling
Forgot to say
2008 model
Post #529280 Thu Jun 29 2017 7:15pm
Bodsy
Site Sponsor
Your car didn't have the aux input next to the 12v socket at the back at all?
Then you found the connections and have added the LR replacement with aux input?
Or added it differently?
Sometimes the 3.5mm jacks have a little too much plastic around them to allow the jack to go in fully. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #529282 Thu Jun 29 2017 7:21pm
Alanfolling
Correct it did not have the aux plug so purchased Land Rover part from ebay
I will try to shave some plastic off I guess it's worth a try
Post #529285 Thu Jun 29 2017 7:30pm
DEVON
Hmmm
Have you tried turning the volume fully up on the input device ?
And then turn the volume up on the head unit ??
The aux input in my sport isn't very loud , so both input/head unit have to be turned up
Pretty high .
Hope you get sorted Thumbs Up
Post #529290 Thu Jun 29 2017 7:57pm
Bodsy
Site Sponsor
You get a much better sound if you have an aux directly yo the back of the head unit as the aux input in the back gets 'processed' which drops the volume levels significantly. Bodsys Brake Bible
See it HERE
Post #529295 Thu Jun 29 2017 8:21pm
Alanfolling
How can I connect direct to back of stereo?
I think I see the wires for aux but not -00% sure
Post #529297 Thu Jun 29 2017 8:30pm
Tom55
Im also looking to bypass the original aux but cant find a new aux kit at all, they all
Seem to just be extensions as opposed to a full kit that you can wire into the wiring behind the head unit. Has anyone done this an have any recommendations?
Post #529607 Wed Jul 05 2017 10:41am
Alanfolling
I purchased this off eBay which connects direct to back of stereo as I did not seem to be getting signal from wires in rear centre console upto the head unit ( checked with a test meter )
Land Rover AUX adapter lead 3.5mm jack in car radio iPod MP3 adaptor CTVLRX003
https://www.ebay.co.uk/itm/221471801587
Post #529609 Wed Jul 05 2017 10:57am
Bodsy
Site Sponsor
Yeah that does the same thing as soldering in an extra aux wire. Thumbs Up Bodsys Brake Bible
See it HERE
Post #529670 Thu Jul 06 2017 1:53am
