Home > Technical > Satnav DVDs now available online |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
Thu Jan 04 2007 12:09am |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Cheers umbertob - I have just emailed them to ensure that the disc available online @ £129 plus vat & shipping is going to be an updated version to that installed in my sept 2005 model?
Thu Jan 04 2007 11:13am |
l Member Since: 11 Jun 2005 Location: Valencia Posts: 232 |
MDP nick at Yoevil does them cheaper I bought mine from him go over to the darkside(www.disco3.co.uk) and you can get details from there. RRS TDV6 HSE BUCKINGHAM BLUE BLACK LEATHER INTERIOR RHODIUM TASMOD SILLS PARROT 3000 EVOLUTION WHITE SIDE REPEATERS RRPORT.CO.UK BROLLY & STICKER
Thu Jan 04 2007 12:01pm |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
Would be useful if they provided version numbers.... 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Thu Jan 04 2007 12:13pm |
Thu Jan 04 2007 3:13pm |
What do you expect = it's German ........ and now you know why xxangelxx buys british
Thu Jan 04 2007 4:35pm |
Thu Jan 04 2007 4:40pm |
Must admit I have used my satnav about half a dozen times , but, when I have ..... I have used the postcode entry as means of identity.
Thu Jan 04 2007 4:43pm |
I used to use my satnav lots and the postcode entry was invaluable. I actually prefer the way the BMW satnav looks to be honest but the only postcode entry you can do is the first 4 characters, not the whole 6. That gets you to an area and it then prompts you for streetname etc, which is no good to man nor beast. The touchscreen ability to type things in is much better than having to pi** about with the iDrive wheel too... so is iDrive crap? No it's not... but that's another argument
Thu Jan 04 2007 4:54pm |
Similar system is used in Audis - but as you say the touch screen of LR / Jag is really the better option for satnav.
Thu Jan 04 2007 5:00pm |
Bish, loading the updated DVD (I assume it will be the same version that ships with MY07 RRSs, if you look at the description of the new disc it says it has listings for movie theaters, coffee houses, etc., which are not included in my version, a 07/05 build) will most likely disable your 1791 "hack", if you care...
Thu Jan 04 2007 6:05pm |
thebishman Member Since: 21 Dec 2005 Location: Kansas, USA Posts: 98 |
Thanks for the tip. I tried pulling on the 'guard' at the bottom of the seat but as it didn't budge, I stopped pulling. When the new disc gets here I'll just pull a damn site harder. BTW, what's with all of the wiring spaghetti down there. LR needs to clean that up at the factory.
Thu Jan 04 2007 11:32pm |
Regarding the disabled 1791 hack, mine is only a (somewhat educated) guess based on the fact that: a) New European map DVDs loaded on 06 LR3/Disco3s and RRSs have reportedly disabled the hack code permanently, and b) The hack is no longer working on any MY07 RRS (and FFRR and LR3) sold in North America. I assume 07s include the same DVD version Navteq is now offering online. I sure hope I am wrong about this, I guess you will be the first "tester" of my doomsday theory. Let us know how it goes when you get the disc, I would have ordered the update myself were it not because of this possibility. I think the new DVDs do contain the dreaded load.kwi - or loading.kwi or whatever that file name is - that modifies the satnav firmware when you first boot it up, for good. That file is notably absent in my version of the map data DVD.
Fri Jan 05 2007 12:09am |
Just a thought
Fri Jan 05 2007 10:54am |
