Home > General > Advice required after seizing my engine. Car a right off :( |
Without an engine, you'd be lucky for £2k
Wed Jun 21 2017 9:46pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
If you want rid of the car as is, id be interested
Thu Jun 22 2017 5:36am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Were you changing the oil and didn't put enough in or dis the oil just get low?
Thu Jun 22 2017 10:31am |
Tina04 Member Since: 21 Jun 2017 Location: Manchester Posts: 3 |
I've decided to get rid as I have found another I've fallen in love with 😍 I've tried to pm you but not allowed as I'm a new member lol.... If you inbox me I can discuss what I've been offered already... 👍 |
Thu Jun 22 2017 6:08pm |
The oil just got low.... annoyed that the oil light didn't come on. It always has before on other cars if need be.. but it certainly didn't come on this time 😔😔 |
Thu Jun 22 2017 6:09pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
you'd better don't drive a car that needs caring. go for a lada or beatle. i know a guy/student time, who had een beatle ( Volkswagen) with a air cooled engine. He drove it for 10 years without ever checking or changing oil, it started every morning even in winter. RRS 3.0 SDV6 HSE Lux
Thu Jun 22 2017 6:13pm |
Tina you need 5 posts to activate PM's but if you add your email address to your profile then a button will appear on the bar below each post you make and that is usable with one post only. Nobody can read your email address in your profile BTW so you shouldn't get a heap of spam 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 22 2017 6:19pm |
Do Land Rovers need engine oil changing? I thought their self administering underbody anti-corrosion coating meant they just need the oil topped up, hence always fresh! It fairly stops my drive from rusting too 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Thu Jun 22 2017 6:48pm |
I can vouch that "Land Rovers" do need oil in their transfer cases............. after driving the front wheels of my 90 into an overgrown and invisible drainage ditch with a big rock just were the transfer case sump was, I drove it more than 100 miles and thought "ummmm it really doesn't want to go very well" then the speedo stopped working just about 1 mile from the indie's workshop. I parked it in their yard, booked it in handed over the keys and said to fix it. Couple of weeks later I got a phone call asking what I had been doing as they couldn't shift the 90 without the aid of a very large fork lift and then a couple of winches and snatch blocks to get it on the ramp.............. there was a 1p piece size hole in the transfer case base, no oil in it and one seized up set of mechanicals inside - it had got hot enough in there to melt bits together and they set solid when everything cooled down. £1100 later it was back on the Scottish hillsides having fun and the transfer case works really well. Problem is that before the seizure my Defender NEVER dripped oil on the drive, now I keep a large sheet of cardboard under it when it is parked up to absorb the drips that it marks it's territory with. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 22 2017 7:32pm |
PM received |
Thu Jun 22 2017 8:19pm |
A friend had a 1800cc Toyota Corolla and he used to drive it until the oil pressure light came on and then topped up the oil - he thought the "oil Light" was like a low fuel light and was telling him it needed to refill the oil (like he would the fuel) - he did not realize it indicated low oil pressure.
Fri Jun 23 2017 4:32am |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 |
It must be OK to drive until the warning light comes on, otherwise LR would have provided a dip stick, surely??!!!!!
Fri Jun 23 2017 11:43am |
2005MY had the horrid to read Citroen long wire old fashioned dipstick with some small yellow plastic beads on it to mark Max and Min points. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jun 23 2017 11:51am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
Early ones have no oil level monitoring |
Fri Jun 23 2017 1:49pm |
