Home > Technical > Range Rover sport 4.4 V8 - Rear Silencer swap |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
No, why wouldn't you use something that you want to use? They're just 2nd-hand stock silencers, they will not break the car. Regards etc.,
Tue Jun 20 2017 5:35pm |
So i assume someone has already chopped your system so the second hand unit will not just bolt back on worth checking |
Tue Jun 20 2017 6:07pm |
If just the backboxes are changed, the rest should be left untouched (unless someone removed the resonator as well, which is a GOOD thing). Regards etc.,
Tue Jun 20 2017 7:41pm |
