Home > Maintenance & Modifications > MY 2013 RRS Heated Steering Wheel Upgrade |
Lonescout Member Since: 30 Aug 2016 Location: UK Posts: 35 |
Wed Jun 21 2017 4:05pm |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
Hi Lonescout,
Wed Jun 21 2017 4:59pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Steve,
Wed Jun 21 2017 11:07pm |
Thanks Col,
Wed Jun 21 2017 11:20pm |
Thanks for those words Steve, but I think the problem is I have to much time on my hands these days and can play about with things and delve into bits and pieces.
Hi, Yes it does but it is negligible, but saying that even the leather part only gets warm not what could be described as hot might be because the wheel is quite chunky or slightly faulty not sure, can't even remember how hot original wheel got. Don't really need it down here middle of winter and has been 18 degrees last couple of days. |
Thu Jun 22 2017 4:16am |
Hi Buckster,
Thu Jun 22 2017 10:19am |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
The IIDtool *should* enable the heated steering wheel as I have seen the option while perusing the app. As for the airbag, I would guess that simply connecting it back up will enable it after a hard reset. |
Sat Jun 24 2017 7:41pm |
Thanks CANROVER for your input . I plan to fit the wheel and new clock ring and do a hard reset. If the new heated steering wheel is not recognised, I will seek an independent specialist to enable the heated steering wheel option.
Sat Jun 24 2017 8:36pm |
Cymru001 Member Since: 07 Aug 2019 Location: Newport, South Wales Posts: 27 |
Hi all,
Wed Sep 04 2019 8:23pm |
Hi, I didn't need an IID tool for mine. Just plug and play. |
Wed Sep 04 2019 8:48pm |
Hi Cymru001,
Wed Sep 04 2019 8:50pm |
Hi Evo5man,
Wed Sep 04 2019 8:55pm |
No, I had to change the clock-spring, you will be very lucky if you already have the heated steering wheel clock-spring fitted. But even with changing the clock-spring, I still did not need a IID tool. Just plug n play for me |
Wed Sep 04 2019 9:08pm |
Great news. Thanks for letting me know. |
Wed Sep 04 2019 10:46pm |
