Home > Maintenance & Modifications > Belt replacements
Morgi27
Belt replacements
Hi guys
I know the timing belt needs changing every 7 years mines due again 2021
But what about any other belts? What's the time frame/milage for any of the others ??
Post #528079 Tue Jun 13 2017 1:48pm
Morgi27
It's a sport 2006 2.7 td coming upto 72k miles
Post #528093 Tue Jun 13 2017 3:36pm
Black Bess
Well the alternator belt has to come off to replace the front timing belt, so you may as well renew that. It drives the alt and the air con compressor. The fuel pump is driven by a belt at the rear of the engine, which should really be changed at the same time. It is a bit of a cow to do, because of the limited access. If that belt fails, no damage will ensue, but the engine will definitely stop!
Of course the tensioner pulleys need to be changed too. Worth having a critical look at hoses too. Spilt oil rots the hoses.
Post #528130 Wed Jun 14 2017 9:33am
