Home > General > RRS cutting out in the fast lane!! |
jednelson Member Since: 29 May 2016 Location: north yorkshire Posts: 2 |
Have had the same problem for about a year.
Thu Jun 22 2017 3:04pm |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Glad you posted this Jednelson,,he's only down road from me & I didn't know he was there,,a chap just round corner from me who sells motorhomes owns the Merrylee's site.
Thu Jun 22 2017 3:14pm |
Crankshaft position sensor?
Thu Jun 22 2017 5:40pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
i agree with Paddy. Might be crankshaft position sensor RRS 3.0 SDV6 HSE Lux
Thu Jun 22 2017 5:55pm |
Small world Tyrefitter, Paul's just down the road from me too!!
Thu Jun 22 2017 9:27pm |
Ian335 Member Since: 09 Oct 2019 Location: Wales Posts: 14 |
My 2011 R R Sport suffering the same problem.Keeps cutting out after 5 miles or 40 miles. Local Indy fitted new LP fuel pump and battery.Still cuts out, told me to refill with good fuel and see if it is cured.Still cuts out.sometimes no warning lights, sometimes a few.I am thinking dirty Erg valves, dirty Maff sensor .Not sure where crank positioning sensor is located.Any advice would be appreciated. Thanks Ian North Wales. |
Sun Oct 13 2019 2:57pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I've heard this can be an issue if the earth strap is corroded. Kev
Mon Oct 14 2019 7:27am |
Thanks Kev,I will check |
Mon Oct 14 2019 5:56pm |
For reference.
Mon Oct 14 2019 6:50pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
The as others have said, this would be the first thing to check (ie change), if it was me. It's one of the few things that can cause the engine to stop (ECU thinks it's no longer turning). Other things like EGR valves, MAP sensors can/will cause rough running, but not stop it. |
Fri Oct 18 2019 10:37am |
This has been sorted at last.It was a faulty crank sensor.Car is running well now. |
Mon Dec 23 2019 3:52pm |
Good to hear it's all sorted Kev
Mon Dec 23 2019 4:50pm |
