Home > Technical > Condenser change help.
zetecor
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Hi I am changing the condenser on my 2006 s/c hst. I am nearly there I have most of the front off but am stuck at the last hurdle.
The rad in front of the ac condenser is held by four bolts, the one in the bottom left is hidden behind the crash bar bracket.
Any ideas?
thanks guys.
Post #527984 Mon Jun 12 2017 10:13am
geoffsnook
Remove the crash bar it is only 8 bolts i seem to remember Thumbs Up
Post #527987 Mon Jun 12 2017 10:53am
Paddi
http://www.rrsport.co.uk/forum/topic44872....=Condenser
Perhaps the above link will help. Best of luck. 2008 MY Java Black TDV8 HSE
Post #527988 Mon Jun 12 2017 10:55am
zetecor
I am so close, mine has the aux rad in front of the condenser. I have removed the main slam panel and the lower crash bar. There is a bolt on the bottom left of the aux rad which is hidden behind the bracket that the lower crash bar was fitted to. Just cant get to it to be able to bring the aux rad forward.
Post #527990 Mon Jun 12 2017 11:29am
geoffsnook
Got a photo might make it easier Thumbs Up
Post #527992 Mon Jun 12 2017 11:47am
zetecor
Thanks, here's a pic of the hidden bolt, I have taken pics all the way and will create a thread when done. I only work in a shop so if I can do it anyone can!
Post #528016 Mon Jun 12 2017 6:07pm
zetecor
Post #528019 Mon Jun 12 2017 6:31pm
zetecor
Managed to do it by cutting the dryer off, gave me access to bolt .
Post #528027 Mon Jun 12 2017 8:20pm
zetecor
Post #528031 Mon Jun 12 2017 9:05pm
phillh
Good work Thumbs Up
Post #528038 Mon Jun 12 2017 10:22pm
zetecor
Cheers Phill, just got to reassemble now, I will create a thread with what I done if anyone would be interested.
Post #528057 Tue Jun 13 2017 7:59am
Nico2104
Hi mate. I would be interested in you going through what you be done as I need to do the same in my rrs s/c. Cheers
Post #528081 Tue Jun 13 2017 2:29pm
zetecor
OK Nico, will do mate, going to reassemble all on Friday.
I think the dealers do if differently by lifting all the rads out from the top as a unit but that means dropping the cooling system. This way is time consuming I would have got to this stage in about 2 hours but seized bolts turned it into a days work.
Post #528083 Tue Jun 13 2017 2:40pm
Nico2104
Cheers mate. Any help would be appreciated. I've also got to fit a air-conditioning pump so looks like it will be a fun weekend for me. Cheers
Post #528084 Tue Jun 13 2017 2:44pm
zetecor
Finally done it:
http://www.rrsport.co.uk/forum/topic48143.html
for pictures.
Post #528818 Fri Jun 23 2017 10:30am
