Home > Technical > Rrs 4.2 SC hdc, lowering suspension, transmission fault |
Can you read what faults it has as we would be searching in the dark as you say you have a cracked rear light which may let water in to electrics and cause those fault you may have a knackered battery which will also give those faults or you could indeed have a suspension issue we will not know without the codes |
Sat Jun 10 2017 5:19pm |
Nico2104 Member Since: 10 Jun 2017 Location: Derby Posts: 56 |
Hi. I have had it plugged in and the only code coming up is u0133 which if I remember correctly is which is dynamic control module. The engine light has come in a couple of times for that but never when the car does the faults I have said . I was wondering if I should maybe buy a new light cluster just to eliminate that. The brake bulb was very faint when on but I took the brake bulb out and cleaned it up as it was corroded on the bulb and the car but once cleaned up the bulb was bright again. Thanks
Sat Jun 10 2017 5:30pm |
Welcome to the forum Nico
Sat Jun 10 2017 6:33pm |
Ok brilliant. I'm going to buy a new back light so there's no wetness inside and new wiring. It has got a battery that is a year old on it but I will check both battery and alternator asap. Thanks for your help and as soon as I have done these I will put an update on here which I'm hoping will be good news. Thanks |
Sat Jun 10 2017 6:36pm |
I just added a bit more for the upper tailgate - if you use the forum search function you will find lots of posts about it. Ahh your one year old battery may be the root of all problems if it is a cheap one - check that it is the right capacity for the car as they are heavy users and put a big load on batteries. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jun 10 2017 6:40pm |
I will definitely check the battery as I used to own Chrysler grand voyager and I literally got through a battery once a year but with it being under warranty I've never had to pay for it. Could you tell me what volts it should be after sitting over night and also then once running as I can check it tomorrow. Really appreciate you help. 1st time I've owned a range rover so any help is appreciated. Thanks |
Sat Jun 10 2017 6:51pm |
Hi again. I have checked my battery this morning after being stood over night and it read 12.02 volts. Upon starting the car it went up to 14.3 volts. I wondered if you could tell me if that is normal. Thanks |
Sun Jun 11 2017 10:23am |
Oh and the battery is a Lucas with 95ah and 800cca. |
Sun Jun 11 2017 10:24am |
U codes are normally just lost communication and there fore can be dismissed most of the time but your battery sounds a little small mine is 110ah and over 900 cca
Sun Jun 11 2017 1:28pm |
Ok thanks. I've had a look and the Lucas battery is a cheaper choice at £74. I wondered if you no if the volt readings I took were low to what they should be. I have found a 105ah over 900cca for £90 which is a varta with 4 years warranty but would it be worth replacing do you think. Thanks |
Sun Jun 11 2017 1:33pm |
Have you changed your rear light yet as i would do that first and make sure everything around it is dry and corrosion free |
Sun Jun 11 2017 2:07pm |
I am picking some lights up tomorrow so will be fixed tomorrow. There is abit of corrosion where the bulb site as I cleaned it up the best I could but still there. I'll make sure I change them and see how that goes. I'm also getting a new upper tailgate switch tomorrow as the one on it is very corroded. Thanks |
Sun Jun 11 2017 2:10pm |
Sun Jun 11 2017 2:12pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
That switch corrosion is not uncommon. Changed mine a couple of years ago as it was starting to play up. 2012 SDV6 - it's missing a couple of cylinders
Sun Jun 11 2017 2:22pm |
