Home > Technical > Servo |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
No you can see much from under the car.
Fri May 26 2017 6:09pm |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 |
Cheers Andy ,
Fri May 26 2017 6:23pm |
You can't see the pipes from under the car. |
Fri May 26 2017 7:49pm |
Not even with a neck like ET ?
Fri May 26 2017 8:01pm |
Get the top engine cover off.
Fri May 26 2017 8:52pm |
Thanks Andy |
Fri May 26 2017 11:02pm |
What actually happens here. It seems a sudden stab at the pedal is fine but holding a light pedal looses pressure from servo ?
Sat May 27 2017 11:29am |
Are the servos all the same, looking to replace and the ref numbers are different but the descriptions say they will fit?
Sat May 27 2017 6:10pm |
You could put a white cable tie into the servo to see if there are sights of oil.
Sat May 27 2017 6:22pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
They will all physically fit and are interchangeable. However, if you have non-Brembo calipers, you can upgrade to the stronger Brembo equipped servo |
Sat May 27 2017 6:37pm |
Ah ok thanks Mike and Andy
Sat May 27 2017 7:54pm |
is there enough vacuum off the inlet manifold to work this servo? or not on tick over revs?
Sun May 28 2017 2:46pm |
Well would you believe it, there's more in here than in the sump!
Mon May 29 2017 12:27pm |
well at least you know why now |
Mon May 29 2017 2:17pm |
