Home > Technical > Servo |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 |
How does it get past the valve |
Mon May 29 2017 6:55pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
Apparently its a bit of a nightmare if you get air into the ABS block. But I guess with an IID you can sort it. |
Wed May 31 2017 9:39pm |
I I D Andy ? |
Wed May 31 2017 9:47pm |
IID = A diagnostic tool; to open valves in the ABS module to release air.
Wed May 31 2017 10:31pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
Completely normal As long as the pedal is rock solid when the engine is off, it's fine |
Thu Jun 01 2017 5:33am |
really Mikey , didn't do that before, unless the engine oil in it was a factor
Thu Jun 01 2017 6:59am |
The servo provides assistance to the braking system. It's also checked as part of the MOT
Thu Jun 01 2017 7:06am |
Well thanks mate , that makes me happier |
Thu Jun 01 2017 7:09am |
I'm still not sorted and slowly loosing the will to live
Thu Jun 01 2017 7:45pm |
Did you disconnect the pipes from the master cylinder then?
Thu Jun 01 2017 7:59pm |
http://www.disco3.co.uk/forum/topic52130.html
Thu Jun 01 2017 8:01pm |
No Andy , from the block and I did try to prop it |
Thu Jun 01 2017 8:36pm |
Thanks Andy I've had a look through Bodsy s bible but I can't find anything other than references to T4 but doesn't say what to do?
Thu Jun 01 2017 8:55pm |
It does sound like it needs a trip to the dealer.
Thu Jun 01 2017 9:35pm |
