Home > Maintenance & Modifications > TDV8 alternator - it's my turn |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
The same happened to me a few weeks ago. I bottled it and paid for my local indy to do the job. It took them 5 hours and I was charged £520. Without doubt, the most expensive alternator replacement I've ever paid for
Wed May 24 2017 4:15pm |
hannez82 Member Since: 17 Apr 2016 Location: VG Posts: 9 |
I've recently done this on my tdv8. The manual states a number of steps that weren't necessary. The two lower bolts are a pain to remove, I had to modify a number of 13mm sockets to be able to release them. Besides from that there wasn't really any trouble once you figure out what parts to remove and how.
Fri May 26 2017 10:10am |
Thanks all,
Fri May 26 2017 11:06am |
Andy d Member Since: 07 Oct 2014 Location: Sheffield Posts: 43 |
ive done 2 they come out of the side you need to remove arch liner fan stays in place quite easy took me 3hours |
Fri May 26 2017 3:31pm |
So far removed the wheel arch liner, lower splash shield, airbox and fan cowling and one turbo pipe. Top alternator bolt is easy but the two lower ones can't be accessed unless two lower turbo pipes are removed?
Fri May 26 2017 5:52pm |
The fan doesn't need to be removed. You can reach the tensioning pulley with a socket wrench.
Mon May 29 2017 9:50am |
Finished the alternator replacement yesterday.
Mon May 29 2017 12:09pm |
