Home > Technical > Gearbox fault, advise please |
Hi, bonkers though this may sound; check your brake light bulbs are working and are correctly fitted. It is a known problem that issues with the bulbs can cause the symptoms you are experiencing. 2008 MY Java Black TDV8 HSE
Sun May 21 2017 6:24pm |
col smith Member Since: 20 May 2017 Location: cornwall Posts: 3 |
Funny enough I changed a bulb the weekend before the issues started, thanks bud I'll try changing the buld |
Sun May 21 2017 6:29pm |
Sun May 21 2017 8:15pm |
Just ordered osram bulbs, I also done a hard re set earlier. Car drives totally different, much more responsive. I'll do the bulbs & keep my fingers crossed. Thanks again for your advise |
Sun May 21 2017 8:41pm |
bainsy19 Member Since: 16 Jun 2017 Location: London Posts: 1 |
I am having the same problem - can you advise if the bulbs resoilved the issue.
Fri Jun 16 2017 11:55am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Sounds like you have an earthing fault on a rear lamp unit. I would look critically at the lamp units and connections at the rear.
Mon Jun 19 2017 9:26am |
