Home > General (L494) > Headlamp Adjustment: Left / Right Hand Drive
Violetpiano
Hi,
Does anybody know how headlamps can be adjusted for driving on the continent? I thought they could be adjusted through the Vehicle Set Up Menu but I don't seem to be able to find it and I can't find anything in the manual either Sad
Thanks
Jas Current RRS: MY18 SVR
Previous RRS: MY15 RRS 5.0L Autobiography
Post #526371 Fri May 19 2017 2:13pm
Tim in Scotland
IIRC there is no adjustment these days, the headlights and dip beam pattern are a compromise to allow temporary use overseas, its only if you take the car permanently over that you would need to buy new headlights. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526373 Fri May 19 2017 2:18pm
Violetpiano
Thanks Tim Thumbs Up
Post #526382 Fri May 19 2017 3:46pm
fkarim
As above, no adjustment required from at least MY12 onwards (possibly earlier too) due to "flat beam pattern" as per the handbook. However, you would have Auto High Beam Assist (as your signature says Autobiography) and that does need changing. It is in the "Driving Features" menu and you can choose from "Drive on the right" and "Drive on the left". Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Post #526385 Fri May 19 2017 4:19pm
Violetpiano
Thanks fkarim, that is probably what I came across previously and thought it was to adjust the headlights rather than the Auto High Beam Assist. Which I am fine with as dips way too late when on Auto in my car so is always switched off.
Post #526391 Fri May 19 2017 5:54pm
