Home > Technical > Poss torque converter |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Mine also has the same very intermittent shudder
Thu May 11 2017 6:56pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Just an update did the 180 mile run no problem slight judder once when at low revs near home. On reading other gearbox issues on here everyone seems to get the judder when the car is warming up then seems to be ok, on mine it's the other way round ie perfect on warm up but int judder when fully warm and no irractic revs
Tue May 16 2017 9:50am |
The judder only occurs when the gearbox oil is up to temperature, and the TC is locked |
Tue May 16 2017 10:56am |
Thanks Mike I did know this but after reading the other threads was beginning to think I'd missed something. Had any experience with Bristol trans, seem to be well thought of on d3 forum or go gen from LR normally go the gen route but just thought I'd ask the question 2008 G4 RRSport TDV8 current
Tue May 16 2017 11:50am |
Well that's the torque converter swapped, just got the rear arb to do now. Do you need to remove the rear bumper when lifting the rear body up the couple of inches or so to get the bar out ? As I don't have access to a wsm how do you bleed the system and would the front bar need bleeding as well ? 2008 G4 RRSport TDV8 current
Mon May 29 2017 8:53am |
karnic Member Since: 18 Jul 2012 Location: dublin Posts: 3 |
With the torque convertor replaced... has the judder gone? |
Tue May 30 2017 1:55pm |
Yes seems to have sorted problem, seems abit more responsive as well less slip through the torque converter will be interesting to see if the mpg improves 2008 G4 RRSport TDV8 current
Tue May 30 2017 5:20pm |
