Home > Technical > green fluid on drive RRS TDV8 2010 |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
it looks like coolant.have you checked the coolant level.?
Wed May 10 2017 3:52pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
That colour of green looks like the UV dye added to check for AC leaks, but I'd highly doubt it would make it all the way to the rear diff
Wed May 10 2017 4:06pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
Steering fluid and fluid for the dynamic response system might be green RRS 3.0 SDV6 HSE Lux
Wed May 10 2017 4:24pm |
eyespider Member Since: 09 Oct 2016 Location: Oxford Posts: 15 |
Hi I checked the coolant first its pink so I don't think it is that. Yes I recently noticed dynamic response was low and topped it up I plugged in my delphi scanner and no fault codes were found for the dynamic response either at the time it was low or the time I topped up. |
Wed May 10 2017 4:36pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Sway bar actuator is leaking. It's an expensive fix so for starters you can try some power steering fluid stop leak. It will buy you a little time and since you will need to get the entire thing replaced what have you got to loose by putting snake oil in your system. I did the exact same thing and it worked and it probably would have held up longer but I got the sway bar replaced anyway. It looks like the exact same leak I had so put that stop leak stuff in there and see what happens. |
Sun May 21 2017 8:46am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
well you have a front one and a rear one and a filter, so the snake oil could do damage to 2 of the 3 remaining components
Sun May 21 2017 9:49am |
Absolutely right Andy,
Sun May 21 2017 10:41am |
