Home > General (L494) > Filters |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 |
I always have carried one, I haven't put much effort into getting one yet though. I read somewhere the V8 diesel doesn't have a replaceable fuel filter. Do you know where yours is located? 2017 MY17 SDV6 SE |
Thu May 04 2017 9:32pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
Interesting surely the makers of the world's best 4WD would have considered that in the outback or anywhere for that matter you can pick up dirty diesel. All interstate trucks run filters and are in a position for easy change. I googled and could not find filters for the current model. I will pull the bonnet today and have a look . I sure hope they are not in tank filter this has to be one of the dumbest places to locate, and yes I know the reason why they are there. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Thu May 04 2017 11:08pm |
Doing a 1000 k run today so thought I'd check under the bonnet . Could not see a fuel filter. Will make some inquiries and find out the go. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Fri May 05 2017 1:50am |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Is this an Australian thing?
Fri May 05 2017 2:06am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1121 |
in the UK, you're never further than 10m from a dealer, or at least a workshop.
Fri May 05 2017 7:40am |
I made enquiry for the SDV6, and the filter is around $170.00. Not sure where it is located yet though, I think it is underneath somewhere. 2017 MY17 SDV6 SE |
Sun May 07 2017 10:56pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
Naks, do you have a link for the L494 workshop manual? MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Mon May 08 2017 10:07am |
+1 for the workshop manual. 2017 MY17 SDV6 SE |
Mon May 08 2017 10:17am |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Well on my car (SDV6 HSE), the fuel filter is fitted to the inner wing, on the right hand side as you open the bonnet. You can`t miss it. It looks like the same canister filter that was used on the old L322, and they cost about £40 here from any motor factor. On the old car though, it was mounted at the side of the transmission, which was a pretty daft location to be fair. |
Mon May 08 2017 1:58pm |
Thnks just got back from a long run still none the wiser where the filter is. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Mon May 08 2017 10:31pm |
I have located the fuel filter, it is easy to access from the engine bay. Sits up high on the LHS above the wheel well and looks fairly easy to replace. Definitely cheaper to buy it overseas. 2017 MY17 SDV6 SE |
Tue May 09 2017 8:37am |
Yes mine was visible when the engine cover was removed. Is replaceable and the tech at the dealer said it would be a good idea to carry a spare. Asked what would happen if blocked he said just water will block the filter said anyone who seriously wants to use the vehicle for off road purposes should carry a spare. Since this seems new to most of the posters here perhaps it's time to investigate where to obtain a spare filter. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue May 09 2017 12:03pm |
Fuel filter part number for mine is LR041978 and I'll upload a photo shortly to show what it looks like in its place.
Fri May 12 2017 7:50am |
The fuel filters are not unique to RR. That number cross-references and is available from your local motor factor! |
Fri May 12 2017 12:48pm |
