Home > Maintenance & Modifications > Air Leak |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
maybe time for one of these, as the lids crack.
Sat Mar 18 2017 4:36pm |
bossman115 Member Since: 27 Aug 2016 Location: essex Posts: 8 |
It might be, but I'm pretty sure its just the pipe that's leaking and not the blue collared socket itself.
Sat Mar 18 2017 7:19pm |
Sorry I didn't think you wanted the pipe. |
Sat Mar 18 2017 7:50pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
It will be the cap, or o-ring inside the collar
Sat Mar 18 2017 9:22pm |
The full story is that a few weeks ago I hit a pot hole and in a moment of madness at the side of the road I jacked the car up inserting the jack in the hole on the compressor cover rather than the chassis. This in turn broke the compressor bracket. I managed to change the bracket without removing the compressor but for a while the car was used with the compressor hanging from the pipes only as the bracket was snapped in two. This caused stress on the pipes which is why I assume it is the pipe that is damaged and not the collar. Can you buy just the pipe from anywhere. |
Sun Mar 19 2017 10:09am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Sun Mar 19 2017 10:49am |
That pipe is quite robust. |
Sun Mar 19 2017 11:08am |
Thanks everybody for your appreciated advice. I shall further investigate this coming weekend. |
Mon Mar 20 2017 11:07am |
OK I am now lost. I have fitted two new plastic pipes to the pump, the metal drier end cover as recommended earlier ion this thread and still after a week my RRS looks like a low rider. All 4 corners lower fully within a week. I can no longer find any leaks but obviously there is still one somewhere.
Tue Jun 27 2017 5:03pm |
Leaking air tank? They do rot Visitor from fullfatrr.com
Tue Jun 27 2017 8:00pm |
Air tank wouldn't cause the car to lower overnight. You have a leaking air bag |
Tue Jun 27 2017 8:46pm |
It all started when I jacked the car up and broke the compressor bracket. The pump hung loose for a week or so by the plastic pipes. It is too much of a coincidence to not be related to this incident. It doesn't go down overnight it takes about a week of no use before it settles to low rider stance.
Thu Jun 29 2017 9:18am |
What about the valve next to the compressor |
Thu Jun 29 2017 9:41am |
Is that where the other end of the plastic pipes go. If so I have sprayed them with leak detector but it is hard to see the complete 360 degrees. Certainly worth a closer inspection.
Thu Jun 29 2017 9:58am |
