Home > Faults & Fixes > ABS warning lights all on |
Suthy Member Since: 09 Nov 2015 Location: Oxford Posts: 12 |
Ok, I have now replaced the rear left speed sensor as this wasn't showing any speed when moving whilst my reader was connected, This made no difference.
Tue Feb 21 2017 8:21pm |
Ok, after getting the workshop manuals from Naks, I have traced the wiring looms, tested for continuity between the wiring sensor connector C0502 and the front connector C2294T, and have found a break in the white cable, as there are no connectors in between these points I will have to run another cable to replace the broken one, I will run a temporary one first just to double check my findings. |
Sun Feb 26 2017 6:50pm |
All sorted, ran a new cable in between the 2 connectors and wired up, all yellow warning lights are now off.
Mon Feb 27 2017 11:29pm |
Well done for your perseverance. thanks for posting. It's all useful info for others Robin
Mon Feb 27 2017 11:53pm |
