Home > Faults & Fixes > Suspension fault yellow warning |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
Is the noise coming from under near side rear door, if so that's the compressor making the noise . Nanocom Evo |
Sat Feb 18 2017 10:06pm |
docian Member Since: 18 Feb 2017 Location: northwest Posts: 19 |
Very annoying indeed!
Sat Feb 18 2017 10:09pm |
Gibson Member Since: 17 Feb 2017 Location: Washington Posts: 39 |
I think so mate it sounds similar to when you have the window cracked open slightly and its like an Echo whirring type sound is a compressor a big job to put right hopefully it will be covered under warranty as it has a three month warranty on |
Sat Feb 18 2017 10:10pm |
It was from a garage buddy but it was from 150 miles from me no light didn't come back on and suspension goes up and down on control is there anything I can do to narrow it down |
Sat Feb 18 2017 10:11pm |
Has the noise from the compressor continued after the restart? (Compressor is located in front of rear nearside wheel, never jack under it like I did once!). Compressor issues can be a common fault, may just be the dessicant but costly if you have to replace them at your own cost. The compressor when working normally is silent (well at least you wont hear it sat inside when engine running) You could ask someone to sit in and raise and lower suspension if its noisy (should just make a comfortable hiss not loud) its compressor related and unlikely to get better on its own accord and will trigger the dreaded lights more frequently. |
Sat Feb 18 2017 10:27pm |
Cheers for the replies lads I will go out and have a look tomorrow when it's light either way car is covered under warranty or if not the garage has sold a car to me that isn't fit for purpose so he will be footing the bill I didn't restart the car I just limped it home as it was dark but will look into what you guys have told me tomorrow if it is a compressor will it be safe to drive until it's repaired or will it cause more problems? |
Sat Feb 18 2017 10:38pm |
Even if the compressor fails completely it should lock in normal height, if it needs changing its not a big job (just and expensive part circaŁ700 for OEM) Couple of hours with an upgrade to the ECU. Glad you bought it from a trader with warranty cos it definately should be covered on that. Hopefully its a third party warranty and you can get it done locally but even if the worst comes to the worst if it completely fails and locks in normal you should be ok to drive but rememeber when driving that you can no longer corner like a sports car so absolutely cautious defensive driving if youre going 150 miles!
Sat Feb 18 2017 10:54pm |
Thanks docian hopefully fingers crossed this will be the end as I have fell in love with the car I've always wanted a rrs |
Sat Feb 18 2017 11:43pm |
Update suspension now saying fault max speed 30mph and back end feels like it's bouncing all over |
Sun Feb 19 2017 10:34am |
Sounds more urgent than a compressor in that case if theres movement at the back end at low speed needs looking at urgent, ring the garage you bought it from, could be anything from airbag gone (does the car look level) to a problem on the rear diff. The ECU error code will narrow it down. Is the warning light red or orange, if orange does it turn red on driving? |
Sun Feb 19 2017 11:03am |
Suthy Member Since: 09 Nov 2015 Location: Oxford Posts: 12 |
I had this problem and found a small split caused by rubbing in the air hose supplying the front right suspension, does any of the corners drop slightly over night?? |
Sun Feb 19 2017 12:54pm |
I haven't noticed any drop but I've only had it two days also moved the suspension up and down and the compressor doesn't seem to make any noise I hope it's just something simple like a hose but the rumbling sounds like a wheel bearing and when the red light came on I noticed the wheels were sitting right in the arches |
Sun Feb 19 2017 1:26pm |
Sun Feb 19 2017 1:44pm |
If your parked on the flat that aint normal. HDC fault may point to battery, can you check the voltage, the "brain" and nervous system of the RRS are all very voltage sensitive, has the time at the dealers killed the battery? When you raise it does it level out on the dashboard info but not physically? (Ride height sensor fault) |
Sun Feb 19 2017 2:03pm |
