Home > In Car Electronics > SAT NAV Display backlight |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
It could be just dry joints if intermittent, but a real sod to get out and check/repair and costs a lot if you pay. May need a new light source LED if edge lit or LCD or plain old tube backlight all depending on model Year fitted. John
Tue Feb 14 2017 11:24pm |
Is it that the perspex in front of the ambient light sensor dirty ?
Wed Feb 15 2017 11:05am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
Where is the AL sensor ?
Wed Feb 15 2017 1:02pm |
little clear blob at the bottom of the rev counter. |
Wed Feb 15 2017 1:14pm |
didn't know it was there.
Wed Feb 15 2017 6:12pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
you normally get a dim display when its cold and the battery power is prioritised by other ecus..if you stop and restart the display should go back to normal brightness.... |
Wed Feb 15 2017 10:05pm |
