Home > In Car Electronics > Battery going flat
ssandps
United Kingdom 2006 Range Rover Sport Supercharged Sumatra Black
Battery going flat
The battery on our 4.2 rrs keeps going flat when the car has been left for more than a day . It had a new battery in November and I have also just replaced the bonnet catch as the alarm kept going off . It had a 100 mile drive on Saturday was then not used Sunday or Monday and was flat this morning Tuesday. Has anyone any ideas what might be causing this . Thanks
P.s it's an 06 plate
Post #517008 Tue Feb 07 2017 4:56pm
Paddi
What sort of use does your car get in terms of daily use? Is it mostly short runs?
If yes to above then try giving the battery a full charge using a decent smart charger and see what happens.
There may be something causing battery drain and there are many possible sources but a common one is the upper tailgate switch. It is easily and cheaply replaceable: just pop it out and slot in the new one.
If you try the above suggestions and the problem persists then you need to check the battery drain. Or get a good independent specialist to sort it out. 2008 MY Java Black TDV8 HSE
Post #517043 Tue Feb 07 2017 9:32pm
ssandps
Hi thanks , yes it does only short trips during the week so i will get a smart charger . Also when we got the car the boot light was disconnected , I reconnected it and replaced the bulb . I have now disconnected it again , will also try the switch as you said .
Thanks again , I will let you know how it is .
Post #517047 Tue Feb 07 2017 10:03pm
ssandps
Is the upper tailgate switch the release switch ? Also how is it accessed?
Thanks
Post #517049 Tue Feb 07 2017 10:17pm
Paddi
Yes, it is the one with the rubber cover. Ideally, open the upper tailgate, remove the plastic trim and push out the switch from the inside. Alternatively CAREFULLY lever out the switch from the outside but this risks scratching the surrounding bodywork. It will probably be corroded and a bit reluctant to come out cleanly. If you search the site for 'upper tailgate switch you'll find descriptions and pictures of how to do it. 2008 MY Java Black TDV8 HSE
Post #517054 Tue Feb 07 2017 11:02pm
ssandps
Thanks for the advise I will let you know how I get on .
Post #517150 Wed Feb 08 2017 7:32pm
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
ssandps,
Did you sort this problem?
Post #524051 Thu Apr 20 2017 8:14am
ssandps
I did change the upper tailgate switch which was corroded , however if left for more than a couple of days it is still going flat . So I have purchased a smart charger and tend to charge it on a sunday when it mainly does not get used . So I still don't know what else it could be ?
Any other ideas ....
Thanks
Post #524100 Thu Apr 20 2017 6:34pm
Alfa Rover
Canada
Hi, had the same problem. turned out to be my starter motor. a good shop will be able to confirm the current draw using an amp clamp and pin point the problem. i did it myself because i love a challenge.
Cheers Neil.
Post #540051 Fri Nov 03 2017 8:11am
Tim in Scotland
Also when you park it do you lower it to access height? This is really important if you you don’t use the car a lot as it will force all the electronics to go into sleep mode, if you leave it in normal height then the electronics will only hibernate and will be looking for your key fob all the time.
Also you could pop into Maplins and invest in one of their solar panel trickle chargers which on your car you should be able to plug into any of the cigarette lighter sockets - cost about £15 but make sure you get one with blocking diodes that prevent battery charge flowing back to the panel at night.......... I used to keep both my 2.7TDv6 and 3.6TDv8 connected up to these when I was way for 5-6 months and never has a problem until I bought later cars with battery management systems that wouldn’t allow the cigarette lighter to remain live when the ignition is off, but I now have a work around for that too in my 2015MY RRS. 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #540067 Fri Nov 03 2017 12:46pm
