Home > In Car Electronics > RRS L320 Bluetooth Module
dunkster74
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi everyone,
I posted previously about retrofitting a Bluetooth module to my 2010 RRS as my audio screen stated "No phone fitted". Having explored I have found that it does in fact have the module in place so I cannot understand why it isn't available. Could this be an LR issue where they have locked it at the factory?
Any thoughts or suggestions greatfully received.
Thanks
Duncan
Post #516471 Wed Feb 01 2017 7:50pm
Bodsy
Site Sponsor
You have paired it to your phone have t you...?
Switch Bt on and then search for LandRover
Pairing code is 2121 Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #516487 Wed Feb 01 2017 9:36pm
dunkster74
Bodsy,
I tried the other day after it arrived and couldn't get it to work. Looked up the error message online and was led to believe I didn't have the module fitted. Just done it again with your help and we have liftoff.
Thanks so much! It's been driving me nuts!
Duncan
Post #516501 Wed Feb 01 2017 10:52pm
steve.rrs
hi bodsy, my phone sometimes wont connect, any ideas
Post #516577 Thu Feb 02 2017 7:29pm
Bodsy
Site Sponsor
What years is your car? If you fill in the profile, it can help us. Thumbs Up Bodsys Brake Bible
See it HERE
Post #516599 Thu Feb 02 2017 9:59pm
steve.rrs
its a 2005 model, you sent me an updated module, works ok apart form now and then i cant find it on my phone, also tried another phone and it also wouldnt find the module, not a major problem just annoying when it wont connect.
Post #517991 Thu Feb 16 2017 8:33pm
Gibson
Hi I'm new to this forum I have an 06 rrs HSE and doesn't pick up Bluetooth that's if it even has it what's this module people have mentioned can anyone point me in the right direction please
Post #518085 Fri Feb 17 2017 8:00pm
Bodsy
Site Sponsor
Do you have red/green buttons on the steering wheel? If not, then you don't have phone module.
Steve,
So we know you have the latest software.
Switch off blutooth on your phone, the. Switch the phone off.
Disconnect your battery cables and hold the cable ends together for twenty seconds before putting back on the battery.
Then switch your phone back on and BT back on. See if it picks it up then. Thumbs Up Bodsys Brake Bible
See it HERE
Post #518086 Fri Feb 17 2017 8:12pm
Gibson
I was going to pm rather than jumping on someone's thread but it won't let me if I don't have that is there anyway I can buy something to connect my phone to my rr? Don't really want to go down the parrot route if possible
Post #518101 Fri Feb 17 2017 11:22pm
Bodsy
Site Sponsor
You can retro fit LR BT but it's expensive now they keep
Putting the module prices up.
Parrot asteroid mini is very popular. Thumbs Up Bodsys Brake Bible
See it HERE
Post #518201 Sun Feb 19 2017 9:18am
johnsporttdv8
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
MY2010 RRS AB TDV8 - Bluetooth Audio streaming?
Hi.
Forgive me if this is the wrong way to post this enquiry but my kids have not finished their training me on how to use forums and all things modern and young.
My question is a simple one. I have an RRS AB MY2010 TDV8 which has just about everything loaded at the factory including the Logic audio upgrade. It would be fantastic to be able to stream from my phone in BT the audio. Is it possible to upgrade this feature in some way as I understand that MY11 on had this ability.
I know you can connect iPod to the special connector but this feature stopped working long ago and was temperamental at the best of times. the BT phone hookup works fine and always has.
Hope some one can assist me. Question SVR On My Wish-List
Post #534046 Tue Aug 29 2017 7:36pm
