Home > Maintenance & Modifications > Flat battery |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4794 |
If you are going to leave a RRS in the garage for 2 weeks, you really need a CTEK charger to keep the battery topped up and look after the battery.
Sat Jan 14 2017 6:15pm |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 |
If your car was purchased with a new battery 11 months ago, then that battery will still be in guarantee. It's worth getting it checked out to see if it's internally breaking down/faulty and if so you should be able to claim for a new one, unless the battery checks out ok then there could be a problem with the charging system on your car or there is an electrical drain dragging the battery down.
Sat Jan 14 2017 6:45pm |
Gmanboyo44 Member Since: 15 Feb 2016 Location: Surrey Posts: 5 |
Thank you will do |
Sat Jan 14 2017 7:53pm |
Done it thanks for the reply |
Sat Jan 14 2017 7:54pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
You've either got a big parasitic drain when it's parked up or the battery is knackered. It could be indicative of an alternator on the way out too, sadly.
Sat Jan 14 2017 8:39pm |
Also if you are leaving the car parked up for more than a few hours it is always best to lower it to access height, when you lock up the car's systems are programmed to go into "sleep" mode which can help reduce battery drain. You will never notice if it has gone to sleep and even when you coming back to it it will automatically wake up, ready to go (unless you have a flat battery!!). I used to leave my 2.7TDv6 and my TDv8 for up to 5 months with them only being driven for a 50 mile round trip every 6 weeks or so and never experienced a flat battery, although I did use a Maplin £10 solar powered trickle charger to condition the battery. It was only when I moved to post 2010MY cars that I ever started to have battery problems - to the extent that my first Evoque would die after only 10 days with a flat battery. Changes of battery to an AGM one and constant upgrading of battery management systems by LR seems to have got around most of the battery flattening problems on the newer cars but it is at the expense of having an audio system that now only runs for 10minutes before shutting down and loosing the ability to plug a trickle charger into the cigarette lighter/ power socket. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jan 14 2017 9:25pm |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Do you mean that you changed yours to an AGM battrry, or that all RRS batteries are AGM now? The reason I ask is that it's a different setting on the battery charger (or will be when I get the car, that is!). |
Sat Jan 14 2017 11:09pm |
