Home > Faults & Fixes > DIY Key Fob Refurb/Repair
adameverett
My old key fob (2005 rrs) was looking a bit shabby and the battery was playing up a bit so I thought it was about time for a fob service. Case and battery sourced off ebay for £10, some fobs have the land rover logo on third button others are a plane button at the bottom. This one was a £5 case fob and came delivered with some black tape stuck over the LR logo to get around trade marks I guess.
Having watched hard core butchery on youtube of people trying to get into their keb fobs with screw drivers/jigsaws etc. I wanted to share my approach that worked really well for me and hope it saves other people some time Thumbs Up
The trick was to just run a soldering iron around perimeter and then a gentle prise open with a screw driver and open she pops Smile The soldering iron cuts through the case like butter so breaking the case in half took about 10 mins tops.
Transfer the circuit board and the ignition key blade over to the new unit.
If replacing the battery you need to release the battery from the circuit board, its held in place with a couple of solder tabs.
Really pleased with how simple it was, advise wearing some gloves. Slips with the iron are easy done as I found out the hard way shortly followed by some expletives.
Other people advise gluing new fob back together, it seemed to click back firmly so will be keeping eye out on that one.
Post #510785 Fri Nov 25 2016 9:31pm
HemoRRS
I like the soldering iron idea, I spent hours when I tried to do mime on my old RR. Sure this will help out lots of people.
Post #510787 Fri Nov 25 2016 9:51pm
adameverett
Originally I was going to dremmel wheel a round it. But when I was ferreting trying to find it the soldering iron idea sort of fell into my hands. Bonus on the iron (no field testing proof) is it is mildly forgiving, if you slip with a screw driver chances your gonna damage the circuit board, dremmel wheel or jigsaws the carnage to the circuit board is not worth thinking about Shocked
Post #510789 Sat Nov 26 2016 7:39am
Fred99
Found a shop in Edmonton north London area did my 2 fobs in 20 mins for about £50 they look brand new
Post #510916 Sun Nov 27 2016 11:47pm
ozzievechi
hi, where about in Edmonton?
Post #510948 Mon Nov 28 2016 1:02pm
