Home > Maintenance & Modifications > Map sensor clean
Rich999
Map sensor clean
Hi all
Whats the best stuff to use to clean the map sensor
Rich
Post #510251 Thu Nov 17 2016 3:12pm
gogsy1956
I used a brake / clutch cleaner - degrease, it doesn't leave any residue when it dries. Just give them a blast to get the deposits off then let them dry, don't rub or poke them with anything as they are easily damaged. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #510255 Thu Nov 17 2016 3:56pm
Rich999
ok thanks Thumbs Up
Post #510261 Thu Nov 17 2016 5:55pm
Russben
+1 for brake & clutch cleaner.
I've cleaned a few of my cars MAP / MAF sensors with it. I'm in the shed, I'll be back in the real world in a minute.
Post #510276 Thu Nov 17 2016 10:12pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
Sorry to appear dim but what's a map sensor and where is it located?
 RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #510283 Fri Nov 18 2016 1:59am
Stuart
LG, >>all will be revealed<< Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #510299 Fri Nov 18 2016 10:40am
Rich999
LG
Put it in the search box loads of info on here. Thumbs Up
Post #510307 Fri Nov 18 2016 1:31pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Here is an excellent write up with pretty pictures!!!! Thumbs Up
http://www.landroverworld.org/threads/lr4-...diy.26761/
Post #510393 Sat Nov 19 2016 11:15pm
