Home > Maintenance & Modifications > Exit lights on bottom of doors |
I replaced mine with LEDs all round, it's worth cutting into the housing a little then you can fit a panel with either 8 or 12 LEDs rather than a single.
Thu Nov 03 2016 2:59pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
perfect.
Thu Nov 03 2016 3:07pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Thu Nov 03 2016 7:04pm |
Do the canbus ones used in the interior lights fade correctly? Robin
Fri Nov 04 2016 9:18am |
Hi
Fri Nov 04 2016 5:36pm |
Cheers Riverblanche. Robin
Fri Nov 04 2016 5:43pm |
Blueskye1 Member Since: 10 Sep 2016 Location: Carmarthen Posts: 80 |
Replaced mine as well
Fri Nov 04 2016 6:51pm |
Not having fitted them yet but I would suspect it is just that the bulb is located at one end rather than centrally. I have seen replacement kits which have LED right across the length of the holder. More expensive but might be worth a try in the future. I'm also wondering about the coloured option for the foot wells. Anyone tried them? Robin
Fri Nov 04 2016 7:01pm |
Thanks
Fri Nov 04 2016 7:12pm |
Answer to the problem I posted & solution
Fri Nov 04 2016 8:24pm |
I've just purchased and fitted these: http://www.ebay.co.uk/itm/272128114698?_tr...EBIDX%3AIT
Thu Nov 10 2016 3:38pm |
Just replaced number plate lights with LED's I had replaced front door lights with LED's but as posted before not happy with only half being illuminated reason in pic so will replace with full LED's as shown in luggage area Rear doors to be done soon old yellow still fitted very poor Andrew My first RRS HSE Purchased June 2016 Java Black 2.7 Date of first registration 22 February 2008 Cousin of the King of Stamford Bridge R.I.P. Ossie |
Thu Nov 10 2016 4:32pm |
I can understand where you're coming from Blueskye1 and it may well be that I'll move on to the full LEDs but for a fiver I thought I'd give them a try. Looking forward to dark to see the improvement.
Thu Nov 10 2016 5:31pm |
Eaters..
Thu Nov 10 2016 5:45pm |
