Home > Faults & Fixes > Range rover sport 2.7 2008 help see the foto.. |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Standard limp mode could be any one of a hundred reasons. Need to get it hooked up to proper code reader to find out what is wrong TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Mon Oct 31 2016 10:51pm |
m8ch1n Member Since: 26 Oct 2016 Location: Lancashire Posts: 28 |
Hi Schizz,
Schizz Member Since: 03 May 2015 Location: Bologna Posts: 26 |
Hi,
Mon Oct 31 2016 11:16pm |
Please help me..... |
Thu Nov 17 2016 9:22pm |
Does the suspension compressor work as it should ? try raising & lowering it continually for 5 minutes after the fault is reset. 16MY Estoril Blue SVR.............
Fri Nov 18 2016 8:43am |
reading on the forums it seems the problem caused by 'brake switch located under the platform of the driver, then replace tell you ...
Fri Nov 18 2016 9:07am |
fixed by replacing the brake pedal switch in the driver's side |
Fri Nov 25 2016 3:34pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Well done Schizz
Fri Nov 25 2016 4:32pm |
