Home > Technical > TDV6 Upgrade |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 |
Driller,
Sun Jan 14 2007 1:27pm |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
hi Driller
Sun Jan 14 2007 4:24pm |
Driller Member Since: 18 Aug 2006 Location: Perth Posts: 80 |
Doc you have PM |
Sun Jan 14 2007 8:24pm |
I believe he'll reapply it for free if an LR service wipes the upgrade, but best check if this is still the case.
Mon Jan 15 2007 10:09am |
That is very true
Mon Jan 15 2007 10:13am |
trying to gauge % is pretty difficult but i found i could be behind two semi's sitting on 90-100, hit the gas, and be passed them both and hitting 140 in around 3-4 seconds . I can assure you that the upgrade will be the best thing you will ever do for your car! |
Mon Jan 15 2007 10:16am |
peterjamesbrown Member Since: 08 Aug 2006 Location: Sydney Posts: 31 |
Hi, Can someone please kindley send me the contact details for the upgrade. I find the wait between the throttle and take off painfully slow.
Fri Jan 19 2007 6:43am |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
Just PM the member "LRtuning"....he's da man! 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Fri Jan 19 2007 8:18am |
