Home > Technical > Wheel bearing causing gear box fault |
TALL DAVE Member Since: 03 Sep 2016 Location: Pencoed, South Wales Posts: 17 |
Hi All
Wed Oct 05 2016 11:08am |
If there's play in the bearing then it could prevent the speed sensor from reading properly. |
Wed Oct 05 2016 1:59pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
What fault exactly ?
Fri Oct 07 2016 1:03pm |
nosmokenopoke Member Since: 09 Jul 2016 Location: Gloucestershire South West Posts: 44 |
I also agree with that. The zf6hp26 has speed sensors in it so i cant see that the wheel bearing would have anything to do with it. What codes you got when its read Jon |
Fri Oct 21 2016 7:47pm |
All sorted now
Fri Oct 21 2016 8:06pm |
Wow Tall Dave. Wheel bearing to mega flush is far apart but like you said all fixed and driving so jobs a good one.
Fri Oct 21 2016 8:12pm |
