Home > Spotted > Camelrock's G4??
Paddi
Camelrock's G4??
Crushed uncomfortably in the rear of a German hatchback on the way back from Grassington to Doncaster yesterday I spotted a very clean and smart G4 parked up at the side of the road.
Bearing in mind that these make rocking horse poop look common I'm assuming this was the aforementioned vehicle. Funnily enough back in 2014 I often spotted another one in Aylesbury on the daily commute. 2008 MY Java Black TDV8 HSE
Post #506771 Fri Sep 30 2016 12:20pm
Camelrock
Wasn't mine sir, unless you where taking a scenic tour as it was parked up in Reeth as I'd gone to work in it as was due an oil and filter change .. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2016 Discovery Sport HSE current
1994 Dakar current
Post #506813 Fri Sep 30 2016 10:48pm
steve.rrs
hi camelrock, have you got allterrain tyres on you rrs, if so what make and size are they
steve
Post #506866 Sat Oct 01 2016 3:28pm
Camelrock
Hi Steve.rrs, in the past I've run cooper LTZ's would of used them on this car but was concerned with the speed rating, insurance issues so I'm running general grabber at 275/45r20 these have a higher speed rating than the coopers and I think comparable in both performance and wear. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #506871 Sat Oct 01 2016 4:40pm
Paddi
Guess not then! Felt sure it must be yours. Do you know of another in N Yorks?
Gave mine a good blast all the way from Herts to Doncaster and back so should have done it a power of good.
I saw 31.8 on the dash as mpg on the way up which is a record Thumbs Up 2008 MY Java Black TDV8 HSE
Post #506874 Sat Oct 01 2016 5:48pm
Camelrock
Hi paddi, there was one from Durham/ Newcastle way one of the 06 v8 petrol cars came across it in Richmond one night and had a mini convoy a couple of years ago. There's also one of the sister cars to mine which lives in the Leeds area a fellow member of the G4OC, the last time I saw that was at the riply l/r show as they where both on the stand together, though it had no graffics on it then but I think they've since putting that right. Probably that car you saw.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #506891 Sat Oct 01 2016 11:25pm
