Home > Maintenance & Modifications > 4.2 Supercharged Exhaust Question
Page 1 of 3 123>
B9BS X
Hi all
Was thinking of removing just the exhaust back boxes and replacing them with a straight through pipe to bring out some more sound, by doing this would the car lose/improve on power? Has anyone on here done this mod and if so how did it sound?
Magnaflow do an exhaust setup with the X pipe but looking at the picture they have removed the back boxes and replaced with a straight through Rolling Eyes
Dont want the car to sound like a boy racer car Rolling with laughter
Will be pleased to hear the V8 burble Mr. Green
 RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #506396 Sun Sep 25 2016 11:32pm
Spanner
I've got the Magnaflow fitted to mine and it sounds glorious, not boy racery at all. Fairly quiet at tickover but lets you hear the engine when you hoof it a bit Thumbs Up
Post #506404 Mon Sep 26 2016 6:47am
B9BS X
Is it a cat back system with a x pipe and one centre box the same setup as the pic above?
How much did the system set u back? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506488 Tue Sep 27 2016 1:32am
Spanner
It's a single box as in the pic but can't remember if there's an x pipe, pretty sure there isnt and it's two separate pipes running into the box.
I bought it off a friend so it cost about a quarter of new
Post #506490 Tue Sep 27 2016 6:41am
Paul_selby
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
May help anyone who hasn't seen what they're exhaust looks like off ! Removed it to replace rear brake pipes. Shows the 2 bolt flange and slip on pipes onto front section.
Post #506496 Tue Sep 27 2016 10:44am
B9BS X
So its a single box in the middle and 2 straight pipes all the way to the tips?
Must sound awesome Thumbs Up
Any chance of a little video clip to hear the sound of your beast? Bow down RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506501 Tue Sep 27 2016 11:43am
B9BS X
Are both boxes in the middle necessary or is the oval pear funny shaped one after the centre box just to quieten the sweet sounds of the V8 Rolling with laughter
Post #506503 Tue Sep 27 2016 11:52am
Socast
The first box is the swirl chamber where the gasses are balanced. The 'snail shell' is the resonator that eliminates most of the bass from the exhaust note. The rear cans control the volume.
I've been trying to get into my local garage to get the snail shell removed and a couple of straight through pipes put in it's place. Not much luck though as he's booked up. Bodsy has previously posted a couple of video clips from his v6 disco 3 before and after the snail was removed. Apparently removing the snail makes a massive difference. Obviously it's quite difficult to guage just how much difference it makes based on a recording done on a phone.
Post #506506 Tue Sep 27 2016 12:08pm
Spanner
I'll see what I can do later when I get home. I think it sounds glorious Thumbs Up
Post #506507 Tue Sep 27 2016 12:10pm
B9BS X
So while im at the exhaust centre and to get a nice growl from my supercharged V8 would you say get rid of the snail shell resonator (the odd looking box) and both back boxes, so straight through pipe from centre box to both tips?
Wow that V8 would definitely start to growl Laughing
Id love the growl on low speeds but do you think it might be too loud on motorway/high speed? And im guessing it may improve a little power? or am I wrong to assume and will lose power? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506512 Tue Sep 27 2016 12:32pm
B9BS X
Nice one spanner that would be great Thumbs Up
Is your RRS also have a Supercharged V8 4.2/5.0? Hows the sound of your car now on motorway speeds? And did u experience any improvement on power after fitting your exhaust? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506514 Tue Sep 27 2016 12:35pm
Spanner
Yes, mines a 4.2 S/C. To me it's fine at motorway speeds, not intrusive at all when you're cruising, just barks a bit when you put your foot down. I felt that there was a slight increase in power but that may be due to me driving it harder because I love the exhaust note Laughing
Post #506517 Tue Sep 27 2016 12:51pm
Spanner
Here's a link to the same exhaust on YouTube. I don't think it quite does it justice but it gives you the idea. Not sure if it'll work as first time posting a link! If not just search range rover sport Magnaflow Thumbs Up
Post #506519 Tue Sep 27 2016 12:58pm
B9BS X
Great stuff
Looking forward to your video later Thumbs Up
Going to visit a exhaust specialist today and get some quotes and hope to fit it sometime next month Mr. Green RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #506521 Tue Sep 27 2016 1:01pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
How did you get on? I've just had the resonator and the back boxes removed. Sounds absolutely glorious, but silent when keeping a steady speed. My favourite noise is when in sport mode, if you're slowing down, and the gear drops, there's a lovely V8 crackling noise.
Anyone know the purpose for the X piece? I've seen it mentioned a few times, and I don't have one on mine. Should I have this installed? 2006 Java Black HST Supercharged
Post #507627 Wed Oct 12 2016 10:13am
Page 1 of 3 123>
