Home > My Range Rover Sport > Amk compressor fitted ... Same fault code as before
D6EML
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Just had an amk compressor fitted today , however the fault code C1A13-64(2E) is still showing .
Old compressor - yellow/red suspension lights , struggled to lower vehicle to access mode
New compressor - lowers quickly to access then yellow light and extended mode appears . Car doesn't raise to extended though .
Could this be a calibration issue / sensor issue ?
Garage said my model never needed a software update
Thanks for any info guys
Dean 2009 TDV8 RRS Stornoway grey
Check out my Autobiography conversion
http://www.rrsport.co.uk/forum/topic41605.html
Post #501718 Tue Jul 26 2016 6:41pm
Disco_Mikey
All pre 2010MY need the software update
Post #501722 Tue Jul 26 2016 7:31pm
Re: Amk compressor fitted ... Same fault code as before
Compressor makes the car go up, it doesn't make it go down.
Post #501724 Tue Jul 26 2016 7:46pm
D6EML
Thanks Mike . Il ring the garage in the morning 👍🏼
Post #501725 Tue Jul 26 2016 8:11pm
B9BS X
Sorry to bring up an old thread but did you resolve the suspension issue with a software update or was it a calibration sensor issue?
Having similar problems and car does not always want to go down into access mode and yellow suspension light comes on.
Was thinking its time for an amk compressor upgrade but dont want to pay for a new compressor and then find the fault is still there as my compressor is working fine all other times Laughing RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #527552 Sun Jun 04 2017 8:15am
