Home > Technical > towbar help please
banditpirate
towbar help please
Can anybody help I have recently bought a 2007 range rover sport I have found a towbar hitch in the back of the car but it has no lock mechanism or lock it's just the towbar no mechanism at all is there any way you can buy the lock mechanism and the bolt that secures it to the car
Post #501600 Mon Jul 25 2016 10:04am
you can get the green handle lock mechanism off ebay
Post #501601 Mon Jul 25 2016 11:13am
banditpirate
I can get the actual lock its the other internal bits I need I can seem to find then anywhere
Post #501604 Mon Jul 25 2016 12:12pm
Sounds like it's goosed if there is no securing bolt Confused , do you have a picture of what you're faced with?
As said above though, you can buy the handle and lock mechanism. It maybe that once fitted you are able to release the securing bolt? ON THE WAY: BMW F21 M140i
Post #501605 Mon Jul 25 2016 12:17pm
banditpirate
Post #501608 Mon Jul 25 2016 12:28pm
Hmmmm, never seen one like that. Best bet would be to give Dan at Duckworths a call and see if he can get you the blueprint or the bits required. ON THE WAY: BMW F21 M140i
Post #501609 Mon Jul 25 2016 12:44pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
hi did you have any joy getting the bits you need I am in the same boat
Post #502251 Fri Aug 05 2016 4:33pm
ShooterNeil
Mine is close to that I need the red ring that sits on the tow bar under the lock and a new lock 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #502258 Fri Aug 05 2016 7:07pm
riverblanche
hi
its missing all the internals and don't believe you can buy them individually, you may be better waiting for one to come up for sale on here and start again.
unless you want to weld it on Shocked Big Cry
Post #502281 Fri Aug 05 2016 11:29pm
