Home > Maintenance & Modifications > RRS 3.0 2010 Cambelt Change |
chufski Member Since: 18 May 2016 Location: Bromsgrove Posts: 13 |
two ways at looking at that I suppose.
Fri Jul 22 2016 3:06pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4351 |
It is much more labour intensive than the 2.7 in any case. I expect the price of the 3.0 will increase after they have done a few
Fri Jul 22 2016 4:06pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
The belt at the front, external to the engine that drives the engine driven fan, power steering pump, air compressor and alternator. (in old terms - the fan belt) The work described on your link has only Cam belt at the front and High Pressure Fuel Pump at the rear and all their associated tensioners etc. As Disco Mikey has alluded to, the serpentine belt and its associated bits and pieces need to be removed and reinstalled as part of the cam belt job so labour is already covered but you will need to pay for these new parts which should be replaced at the same time - not all that expensive. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Fri Jul 22 2016 4:25pm |
Baz0195 Member Since: 29 Jun 2018 Location: Telford Posts: 23 |
Hi chufski.
Sun Mar 03 2019 8:46pm |
Try Alltrack 4x4 in Malvern. They don't lift the body for belts |
Sun Mar 03 2019 8:58pm |
And FYI, we dont lift the body either. Perfectly doable with the body in situ, and managed to get the price down to £675 Inc VAT |
Sun Mar 03 2019 9:01pm |
Thanks mate I have been quoted £668 inc vat for front & rear belts but the first mechanic I spoke to said £668 inc vat for front & rear belts so I asked about the hpfp belt & he said that will be a body off job & over £1,000 but when I enquired again at a later date I was quoted the same £668 for all 3 belts without body off All this does not include water pump replacement as I was previously advised to replace the water pump. What do you think
Sun Mar 03 2019 9:30pm |
Water pump is driven off the Aux belt, so no major dramas or replicating work if it did need done in the future |
Sun Mar 03 2019 10:42pm |
Ok cheers mikey would you recommend getting it done tho whilst there in there. When I brought the car I was told the timing belt was due at 10 years or 100,000 miles but I have just found out it is 7 years or 112,000 miles, more fool me for not doing my homework so I really need to get it done as it’s over 2 years due & on 90,000 miles & don’t know if it has been done, tried previous owner & service book stamp garages & no luck not happy & could do with some advice on what to get done |
Sun Mar 03 2019 10:59pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
whats the deal with the rear belt on the 3.0?
Mon Mar 04 2019 5:16am |
