Home > Technical > Does battery need replacing |
Didn't you mention in previous posts that you were also getting the 'HDC fault system not available' . This is often the first indication of a battery that is failing or needs recharging.
Thu Jun 09 2016 6:00pm |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
Thank-you. The joys of owning a RRS. |
Thu Jun 09 2016 6:36pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Just adding to this thread.
Mon Jul 04 2016 4:43pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
In my other thread I have been going through this - faults - starts OK after a glow plug cycle - hard to start otherwise - sometimes the trip meter resetting - yesterday doors locked and unlocked by themselves during start.
Tue Jul 05 2016 1:33am |
Thanks for the reply. Just looking at the best battery for amps and cost. |
Tue Jul 05 2016 7:24am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
This: https://www.tayna.co.uk/EA1000-Exide-Premi...P7488.html "D2BOYS" gets you a few extra quid off. Visiting from DISCO3.CO.UK
Tue Jul 05 2016 9:04am |
Thanks for that. I will call them this afternoon. 😉 |
Tue Jul 05 2016 10:18am |
Ordered new battery from tanya batteries and mentioned D2BOYS and got 70p discount. Fitting tonight. Let's hope it sorts the satnav and radio problems out. |
Wed Jul 13 2016 5:35pm |
Fitted new battery. Satnav and radio still play up. What's next???? Must be battery drain somewhere. When I fitted the battery there was a spark so something is always running. Any ideas. |
Thu Jul 14 2016 10:11am |
You could try that other forum favourite of a hard reset ? Disconnect both leads from battery and connect them together for 30 seconds or so using e.g. a jump lead.
Thu Jul 14 2016 1:02pm |
This sounds like the problem I'm having.
Fri Jul 15 2016 9:07am |
Still playing up. I have bridged the bonnet switch and locked the car. Heavy duty charger charging battery. But it will not drop below 1.3 amp. If I remove the charger and use a smart charger the volts drop within a minute or so.must have a drain somewhere. Also noticed if I use back and front heated screens with the program button, when I switch off front screen the radio go off for second. The car starts first time every morning but as soon as I rev it the satnav screen goes on and off for a good 30 seconds and radio goes on and off. Also sometimes when I press brake pedal it won't release the gear selector.
Wed Oct 05 2016 5:31pm |
Car must have gone to sleep as smart charger is holding the voltage. |
Wed Oct 05 2016 6:18pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
I am not sure what year your vehicle is, but the early ones with seperate CD player with disc for Sat Nav, have been known to cause problems, due to not turning off properly, so still on all the time which drains battery causing all sorts of gremlins.
Wed Oct 05 2016 9:37pm |
