Home > Technical > 12V socket making to work whe engine off
odin
Croatia 2007 Range Rover Sport TDV6 SE Tonga Green
Have anyone managed to enable the 12V sockets whe engine is turned off? this is very annoying for me, not being able to charge my bluetooth headset overnight in the car.
Post #68152 Mon Nov 27 2006 9:36pm
I would think that it would be possible to take a feed from an interior light but this would only mean that the power would switch off after 1/2 hour - the on board computer will shut it down. Would like to be wrong though. 2005 Zambezi TDV6 - Gone but not forgotten
Post #68153 Mon Nov 27 2006 9:39pm
odin
Maybe it would be possible to connect it on wire which controls the hazard lights, I can't think of anything else which would be on when the power is off...
Post #68159 Mon Nov 27 2006 9:48pm
good point. 2005 Zambezi TDV6 - Gone but not forgotten
Post #68160 Mon Nov 27 2006 9:50pm
pulse
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
You could take a feed off the perm 12v at the back of the radio
Post #68162 Mon Nov 27 2006 9:53pm
I think that might have a time limit on it. 2005 Zambezi TDV6 - Gone but not forgotten
Post #68164 Mon Nov 27 2006 9:55pm
WOODY179
I believe TFC over on the DISCO3 site found where to take a permanent 12v feed from. Take a look at the following picture - should be the same on the RRS.
Post #68173 Mon Nov 27 2006 10:19pm
odin
thank you very much. I hope that I will be able to solve this.
Post #68174 Mon Nov 27 2006 10:32pm
