Home > Wheels & Tyres > Scary nuts |
Maybe you will be needing this
Fri May 13 2016 5:43pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
These are "new" nuts being only about 12 months old. Got them from AF I think but can't remember for sure. Mine have loose covers but that's because every bloody garage and tyre place uses an air gun at some point it seems.
Fri May 13 2016 6:10pm |
Good idea mate, sounds like you had a lucky escape 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri May 13 2016 6:21pm |
Found a couple of swollen nuts on the loose wheel so replaced with a couple of spare nuts.
Sat May 14 2016 1:32pm |
I think the swollen nuts are a bit of a common issue from what I have seen on the disco forum mate, and the locking nuts are no better either
Sat May 14 2016 1:47pm |
Looking at the nuts, it's not that they swell, it's that the pressed on covers are loosened by the air powered impact wrenches "professionals" seem to use. It's a bloody poor piece of design by LR in my opinion; what's wrong with solid wheel nuts that don't have a silly cover? As they are, they can effectively strand you at the side of the road with a puncture because you can't undo the nuts! 2012 SDV6 - it's missing a couple of cylinders
Sat May 14 2016 3:01pm |
