Home > Wheels & Tyres > Tyre Wear Question... |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, i am due two new front tyres on the sport, question is they have both worn the inner and outer edges of both tyres evenly, but left quite a bit of meat in the center. I have always kept the tyre pressures checked but any advice would be appreciated, thanks 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sat May 07 2016 5:43pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
When you say checked @ what psi?
Sun May 08 2016 2:58am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Should running 33 front, 36 rear, is the pressure gauge calibrated ? 2008 G4 RRSport TDV8 current
Sun May 08 2016 7:48am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
33 front and 36 rear is only good for light loads (ic max 2/3 people , no lugage, moderate speeds). Max pressure rates are 38 and 42 respectively, but makes the suspension very harsh
Sun May 08 2016 5:11pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
Sun May 08 2016 6:27pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
The label on my door of RRS has several alternatives for tyre pressures shown for numbers of people weight of rear loads etc with a much wider range of tyre pressures. Could this be for the 2011-2013 facelift models?
Sun May 08 2016 10:45pm |
Johnski, all Land Rover products since about 2001 have had a plate like that either in the driver's or front passenger's door jam. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon May 09 2016 8:39am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
If they are wearing just on either the inside or outside edge on the same axle, then I'd look at getting the 4 wheel alignment checked as CRACKA suggested.
Mon May 09 2016 2:58pm |
