Home > Maintenance & Modifications > Mega flush by Geoff. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
How much please? |
Wed Apr 13 2016 10:58am |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Areas covered to please? John
Wed Apr 13 2016 1:53pm |
Chris80 Member Since: 05 Oct 2015 Location: Kent Posts: 58 |
Probably best you contact him direct to discuss prices, location etc.
Wed Apr 13 2016 7:22pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
OK, a lot of missing info... You say Geoff did this for you but you provide no info...
Mon Apr 18 2016 1:48pm |
Well you could do what I did when I recently bought my Sport.......... Do your homework then contact the the people that are well recommended on this site and on the sister sites.
Mon Apr 18 2016 2:27pm |
Well I suppose I could, yes, valid point but going on just Geoff, which I did, brought up very little in the search so no mention of price, work done or contact info. Which brings me back to my point....
Mon Apr 18 2016 3:29pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
Mon Apr 18 2016 3:53pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
To cut a long story short,, a mega flush is a means of changing the Gearbox oil. If the oil is changed just by normal methods,, taking out the plug and letting it drain, not all of the oil actually drains out. A mega flush uses a special machine,,, bit like a dialysis machine, it removes all of the old oil and replaces it with new. Most people have it done as per the Gearbox manufacturers recommendation,, at 75k miles or thereabouts. In the UK prices range from 250 - 300 pounds. The Gearbox is normally reset at the same time so that it basically learns a new set of changes depending on your driving style. 2010 RRS, TDV8
Mon Apr 18 2016 5:26pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
ZF suggest a flush 50-75k or sooner with arduous use, and I can't emphasise enough how important it to get the fluid changed in a timely manner. I second the recommendation for Geoff - he's based in Kent but is mobile and often gets about on flushing trips. Visiting from DISCO3.CO.UK
Mon Apr 18 2016 5:56pm |
Thanks Gogsy,
Canrover,, the thing to keep in mind is this process is carried out using a Winns transverse flushing machine,, not a lot of dealers in the UK have them as they are quite hard to get hold of and are not cheap. That is why a lot of dealers simply drop the oil a couple of times to get as much oil out as possible. Have a look on U tube for a one in action and make sure that is the method they use.
Mon Apr 18 2016 7:32pm |
Thanks Gogsy,
Tue Apr 19 2016 2:09pm |
Hey Gogsy,
Sat Apr 23 2016 2:53pm |
Yes, that looks very similar to machine that Geoff has. His machine is made by Wynns.
Sat Apr 23 2016 4:01pm |
