Home > Technical > "Low battery warning - start car" |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Hi,
Tue Apr 05 2016 4:19pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Yes, easy to use. If you have twin electrics or the 13 pin type then you can charge via an adaptor lead from the shop on here. Or simply connect to battery and earth point....lots of posts on here about it Visitor from fullfatrr.com
Tue Apr 05 2016 5:19pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
A CTEK 5.0 should be plenty.
Tue Apr 05 2016 6:29pm |
denny111 Member Since: 07 Dec 2014 Location: Kent Posts: 98 |
hi mate
Wed Apr 06 2016 9:50am |
I ordered a M8 comfort connector off ebay £4.95. (they are a bit longer)
Wed Apr 06 2016 12:14pm |
ok thanks for the info |
Wed Apr 06 2016 1:28pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
I get the same warning if I park up and put the TVs on, this warning comes in at about 2min later.
Wed Apr 06 2016 6:46pm |
LR advice: never play with the toys with engine off Visitor from fullfatrr.com
Wed Apr 06 2016 8:35pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
So why fit them if not suitable for use if engine not running. Crazy. John
Wed Apr 06 2016 9:56pm |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5584 |
Totally agree Johnski
Wed Apr 06 2016 10:25pm |
I get warnings when TV or DVD playing, and strangely the Radio turns itself off after 15 minutes if put on to listen to. John
Wed Apr 06 2016 10:57pm |
