Home > General > lowering suspension goes to Extended Mode
tarkuk
United Kingdom 2008 Range Rover Sport Supercharged Stornoway Grey
Hi all
Juat got my self a RRS 2008 SC and when i lower the suspension it goes in to extended mode and the suspension rises however if i press the button again it stays low but extended msg is shown.
Any ides on what it could be, looing at the 4x4 screen the red dots are level and nothing looks out of place
Thanks
Post #489226 Sat Feb 27 2016 10:28pm
Bodsy
Site Sponsor
Heights need calibrating or you have a dodgy height sensor. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #489240 Sun Feb 28 2016 12:23am
tarkuk
Hi Bodsy
thank you for responding. do you know anyone who can do this in London apart from a dealer not sure what the cost would be to recalibrate or replace the sensors
Post #489247 Sun Feb 28 2016 12:36am
scarey
could be a clogged up cone filter on the compressor....
Post #489584 Tue Mar 01 2016 4:12pm
Has anybody lowered the suspension using one of the EAS Control lowering tools, as have seen them lowered to far, and are OK in Normal Ride Height, but if Access height is selected car lowers to far and thinks it has bottomed out and Rises to clear Obstacle.
Post #489585 Tue Mar 01 2016 4:33pm
tarkuk
Hi All
just to let you know that I took my RR to Aylmer Motorworks to have a look at the issue.
They plugged my car in to the computer and no error codes and all is fine so they got the car up on the ramp and looked at the Height sensors and found that the rear left the connection had some slight corrosion so they cleaned that off and now its working fine.
the best part is this work was paid for by my warranty that came with the car which is Autoguard Warranty.
Regards
Post #490605 Fri Mar 11 2016 12:01pm
